Einleitung
2007-2011 Toyota Camry's were installed with a sun visor that was later recalled due to a defect in the inner plastic body. The two halves of the visor that connect around the lever arm begin to pull away from the arm that attaches it to the interior of the car. Making the arm unable to hold the visor in place effectively, increasing the risk of it obstructing the view of the driver. Over time most visors even fall off the connecting arm completely. This guide provides a simple fix to the defect, providing a way to reinforce the faulty connection that is causing the problem. Follow our guide with the step-by-step process to insure that it will be fixed correctly.
Was du brauchst
Remove cap and squeeze metal brackets revealed underneath to loosen and remove from interior of car.
Tear open the seam surrounding the hole that the swing arm inserts into with a seam ripper.
Pull the fabric back to show the inner casing.
Reinsert the swing arm back into the visor, make sure the metal prongs on the swing arm line up with the holes on the visor.
Fold the aluminum plate around the outer casing to reinforce the arm in the casing.
Screw a one inch screw through the metal plate and plastic casing using a phillips head screwdriver.
Adhere the two halves of the torn seam back together over the outer casing and the aluminum plate using upholstery glue.
Realign the metal clips of the swing arm to the hole in the car and snap the visor back into place.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
25 Kommentare
For future readers: simply remove the visor from the ceiling as described in step one. No need to separate the visor from the swing arm in advance. Proceed through the steps as described. I used a 3x5 tie plate (http://www.homedepot.com/p/Simpson-Stron...) and it worked beautifully. I screwed the plate (2nd row of holes) to the edge of a piece of wood about the same thickness as the visor and bend it around that wood as a guide. It resulted in the 1st and 3rd rows of holes aligning so that I could put the screws all the way through and secure with lock nuts. I used #6-32, 1.5" screws (2) and #6-32 locknuts (2). The holes in the tie plate were ever so slightly too small for those screws but a drill bit one size too large for the hole widened it perfectly with ease. The screws were too long (1" was too short) and needed to be cut off with a dremel afterwards. (I couldn't find a 1.25" length screw for the job.)
Well, for most of us the visor has completely fallen off of the swing arm already, so it's a non-issue. But thanks for the condescending reply to the OP who took the time to write an incredibly helpful review.
This is a Toyota design flaw. It is a safety issue and is negligence on their part not to admit failure and issue recalls. This is in no way isolated to the Camry. It occurs in RAV4s, Tacomas, Highlander's, Tundras and possibly more.
My wife's 2012 Venza has this problem, as does my 2011 Camry.
