Zum Hauptinhalt wechseln
2007 Honda Accord Bass Speakers Replacement
Was du brauchst
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: Schritt 1, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: Schritt 1, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: Schritt 1, Bild 3 von 3
    • Use the plastic opening tools to remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: Schritt 2, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 2, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 2, Bild 3 von 3
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: Schritt 3, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 3, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 3, Bild 3 von 3
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: Schritt 4, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 4, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 4, Bild 3 von 3
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: Schritt 5, Bild 1 von 2 2007 Honda Accord Bass Speakers Replacement: Schritt 5, Bild 2 von 2
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: Schritt 6, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 6, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 6, Bild 3 von 3
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: Schritt 7, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 7, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 7, Bild 3 von 3
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: Schritt 8, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 8, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 8, Bild 3 von 3
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: Schritt 9, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 9, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 9, Bild 3 von 3
    • Drill a hole through the firewall located on the foot well of the driver's side under the steering wheel.
  10. 2007 Honda Accord Bass Speakers Replacement: Schritt 10, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 10, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 10, Bild 3 von 3
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: Schritt 11, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 11, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 11, Bild 3 von 3
    • Run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: Schritt 12, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 12, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 12, Bild 3 von 3
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: Schritt 13, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 13, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 13, Bild 3 von 3
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Insert the wire harness back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: Schritt 14, Bild 1 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 14, Bild 2 von 3 2007 Honda Accord Bass Speakers Replacement: Schritt 14, Bild 3 von 3
    • Put the head unit and the panels back into the car.
Abschluss
To reassemble your device, follow the instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
Frankie
253 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G2, Riel Spring 2021 Mitglied von UMass Dartmouth, Team S1-G2, Riel Spring 2021
UMASSD-RIEL-S21S1G2
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 69
Insgesamt: 3,126
