Zum Hauptinhalt wechseln
2007 Hyundai Sonata Cabin Air Filter Replacement
Was du brauchst
  1. 2007 Hyundai Sonata  Cabin Air Filter  Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 1
    • Make sure the car is off and the passenger door is open.
    • Locate the indent on the inner side of the door.
  2. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 2, Bild 1 von 2 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 2, Bild 2 von 2
    • Then gently pull until you hear three clicks.
  3. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 3, Bild 1 von 1
    • Open the glove box, and make sure nothing is in there.
    • Next, gently push down until it comes loose from the clips on the left and right.
  4. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 4, Bild 1 von 1
    • Once the glove box is loose, locate latches, on the left and right top and bottom corners, and pinch together, at the same time, to free the air filter.
  5. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the air filter straight out.
  6. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 6, Bild 1 von 1
    • Push the air filter in the four corners to release the old one.
  7. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 7, Bild 1 von 1
    • Place the new air filter in the square and push the four corners to lock it into place.
  8. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 8, Bild 1 von 1
    • Place the filter back into the correct spot until you hear two clicks.
  9. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 9, Bild 1 von 1
    • Then, push the glove box up back into place.
  10. 2007 Hyundai Sonata  Cabin Air Filter  Replacement: Schritt 10, Bild 1 von 1
    • Next, place the dash cover, taken off in the first step, back into its location; listening for three clicks.
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I haven’t tried it yet, but the instructions appear very good.
awmccready - Antwort
I got the filter out. There is a rod with a spring that connects to the passenger side of the glove compartment door that had to be detached from the door and then put back on for reassembly. Took a bit of tugging to get the door open and the filter drawer out. There has been a very bad smell for weeks. So it was not a surprise that there was a rodent nest on top of the filter. The filter was black and smelled terribly. Still don’t know how the rodent got into the filter chamber from the outside. We’re fairly sure that it got in, when the car sat in the hospital parking lot for a few days a month or so ago, while my wife was suddenly admitted for two lung blood clots. There was no visible carcass, but it could still be in the duct work between outside and the filter, if the terrible odor persists.
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 15
Letzten 30 Tage: 53
Insgesamt: 1,989
