Zum Hauptinhalt wechseln
2007 Mazda 6 Door Speaker Replacement
Was du brauchst
  1. 2007 Mazda 6 Door Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 2007 Mazda 6 Door Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 2007 Mazda 6 Door Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Pop open the hood and locate the battery.
    • Loosen the bolt on the positive terminal with the 10mm wrench.
    • Pull up and detach the terminal to disrupt power flow.
  2. 2007 Mazda 6 Door Speaker Replacement: Schritt 2, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry open the screw cover on the inside of the handle with the small flathead screwdriver.
    • Unscrew the handle with the phillips screwdriver.
  3. 2007 Mazda 6 Door Speaker Replacement: Schritt 3, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 3, Bild 2 von 2
    • Pull the handle cover down and out of its pocket.
    • Slide the cover to the right off the handle.
    • Detach the tab on the back of the locking mechanism to completely remove the cover.
  4. 2007 Mazda 6 Door Speaker Replacement: Schritt 4, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 4, Bild 2 von 2
    • Peel off the rubber insert in the inner arm rest.
    • The insert should be glued down if this is the first time you are disassembling the door.
    • Unscrew the inner arm rest panel with the phillips screwdriver. This screw is holding the arm rest panel together.
    • On the passenger side the screw will be inside the upright handle. Pry off the handle cover and unscrew the screw hidden inside.
  5. 2007 Mazda 6 Door Speaker Replacement: Schritt 5, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 5, Bild 2 von 2
    • Pry the power window switch case out of the arm rest with your flathead screwdriver.
    • Detach all tabs on the back of the switch case to remove completely.
  6. 2007 Mazda 6 Door Speaker Replacement: Schritt 6, Bild 1 von 1
    • Pop out the cover by the outside mirror to relieve door tension.
    • Pushing from the left side of the cover might help.
  7. 2007 Mazda 6 Door Speaker Replacement: Schritt 7, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 7, Bild 2 von 2
    • Pop out the door panel starting on the side closest to the door hinges.
    • You will have to tug it roughly to detach the tabs holding the panel in place.
  8. 2007 Mazda 6 Door Speaker Replacement: Schritt 8, Bild 1 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 8, Bild 2 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 8, Bild 3 von 3
    • (OPTIONAL) Pop off the light cover.
    • Use a flathead screwdriver to press the clip holding the light from the back of the door and pull the lightbulb out.
  9. 2007 Mazda 6 Door Speaker Replacement: Schritt 9, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 9, Bild 2 von 2
    • Lift the door panel up and out to remove.
  10. 2007 Mazda 6 Door Speaker Replacement: Schritt 10, Bild 1 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 10, Bild 2 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 10, Bild 3 von 3
    • Unscrew four bolts holding the speaker with the ratchet.
    • Pull out the speaker.
    • Detach the connector in the back.
  11. 2007 Mazda 6 Door Speaker Replacement: Schritt 11, Bild 1 von 2 2007 Mazda 6 Door Speaker Replacement: Schritt 11, Bild 2 von 2
    • Cut and strip the wires that were connected to the speaker.
  12. 2007 Mazda 6 Door Speaker Replacement: Schritt 12, Bild 1 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 12, Bild 2 von 3 2007 Mazda 6 Door Speaker Replacement: Schritt 12, Bild 3 von 3
    • Check the speaker connectors to determine which one connects to the positive and negative terminals. The speaker should have a + sign next to the positive terminal.
    • Splice the wires from the door to the new speaker's wires making sure to connect the correct wire polarity. (The small connector wire from the speaker is positive.)
    • In the driver side door, the positive wire is red and the negative wire is white.
    • In the passenger side door, the positive wire is blue and the negative wire is yellow.
    • Cover and crimp the wires with the butt-end connectors.
  13. 2007 Mazda 6 Door Speaker Replacement: Schritt 13, Bild 1 von 1
    • Attach to the speaker terminals.
    • The speaker should indicate the positive terminal with a + sign.
  14. 2007 Mazda 6 Door Speaker Replacement: Schritt 14, Bild 1 von 1
    • Insert the new speaker and screw into place.
Abschluss
Ein Kommentar
the passenger side is completely different
Robert Klaiber - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 4,950
