Zum Hauptinhalt wechseln
2008-2015 Chevrolet Cruze Oil and Oil Filter Replacement
Was du brauchst
    • Drain oil from oil pan until flow comes to a slow drip.
    • Remove the oil filter from the Engine Oil Cooler assembly, and replace Oil Filter and O-Ring with new parts.
    • Tighten Oil Filter Cap down to 25 N-m.
    • Replace oil pan drain plug with new part and torque down to 14 N-m.
    • Pour 4.25 quarts of engine motor oil into by removing the oil filler cap on top of cylinder head.
    • Tighten oil filler cap down tightly.
    • Let engine run for 5 seconds and shut off engine.
    • Check engine oil level using a clean rag and the oil dipstick.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew T
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 66
