Einleitung
This guide explains how to replace a 2010 Ford Escape air filter. This step-by-step guide shows what the user needs to do in order to replace the air filter in this vehicle. It is important to replace the engine air filter to allow clean, debris free air to flow throughout the car. The air filter also allows the car to run smoothly and use less fuel when there is a clean air filter inserted.
Was du brauchst
Pull the open hood tab found under the dash by the foot pedals.
When hood is opened, locate the air filter compartment, circled above.
Align the circular bump in the air filter compartment to the circle on the air filter itself.
Push down and to the right to insert the new air filter.
