Einleitung
How to replace the turn signal in your Honda Accord.
Was du brauchst
ifixit doesn't allow linking to specific times in the video, so you'll have to drag through to the right time in the video:
LEFT Turn Signal (Driver's side): 8:09 in video.
RIGHT Turn Signal (Passender's side): 9:39 in video.
The beginning and end of the video includes a lot of talking. Really, just drag through to the specific time you need.
This video does not go over headlight replacement. Other videos I have looked at suggested taking off the underside body panel for the front wheels.
It may be possible to reach the headlight using the same method as the turn signals. Please update this guide if it works for you.
Turn signal image credit: By OSX - Own work, Public Domain
2 Kommentare
Showing ALL the steps including what some might consider pointless is all important to a novice like myself. I am referring to the removal of drivers side air intake and duct as such. And to get a little more granular when showing the removal of the duct, as only needing to be pulled hard and not having to worry about any hidden clips etc. Well done. I will no doubt return here again.
Sharon
This is not for turn signal replacement. Its for repalcing turn signal bulbs. Please edit to refelect that. I was hoping this was a how to for replacing the turn signal piece that controls the turn signals.
