Einleitung
The following is a guide on how to replace the battery for the key FOB on a 2008-2010 Audi A3 Sportback. The key fob utilizes the CR2032 lithium battery. When you try to lock or unlock your car doors with the key FOB and they do not do so, then you need to replace your key FOB battery. See the troubleshooting page.
Was du brauchst
With the tip of a flat head screwdriver, insert it under the edge of the key fob and push against the back cover to pop it off.
Remove the round CR2032 battery from the fob back cover with a plastic spudger or opening tool.
4 weitere Personen haben diese Anleitung absolviert.
