Zum Hauptinhalt wechseln
2008 BMW 335xi Blower Motor Replacement
Was du brauchst
  1. 2008 BMW 335xi Blower Motor Replacement, Blower Motor: Schritt 1, Bild 1 von 3 2008 BMW 335xi Blower Motor Replacement, Blower Motor: Schritt 1, Bild 2 von 3 2008 BMW 335xi Blower Motor Replacement, Blower Motor: Schritt 1, Bild 3 von 3
    • Put the passenger seat all the way back to create as much room as possible.
    • Remove any objects from the floor of the passenger seat so that you have a clean workspace.
  2. 2008 BMW 335xi Blower Motor Replacement: Schritt 2, Bild 1 von 2 2008 BMW 335xi Blower Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove the panel on the right side of the trunk to expose the battery.
    • Twist the knob to unlatch the door so that you can remove it.
  3. 2008 BMW 335xi Blower Motor Replacement: Schritt 3, Bild 1 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 3, Bild 2 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 3, Bild 3 von 3
    • Use a 10mm socket wrench to loosen the bolt and remove the negative battery terminal.
    • Then tuck it to the right side and wrap it in a rag.
    • This prevents the circuit from being accidentally completed while you continue working.
  4. 2008 BMW 335xi Blower Motor Replacement: Schritt 4, Bild 1 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 4, Bild 2 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 4, Bild 3 von 3
    • Remove the two T20 Torx screws located below the glove box.
    • One is located all the way on the right and the other one is located all the way on the left.
    • The panel will drop down as the screws are removed. Pull the panel away slightly.
    • Careful not to let it drop all the way down as a wire is connected to the footwell light.
    • Disconnect the black cable for the footwell light.
  5. 2008 BMW 335xi Blower Motor Replacement: Schritt 5, Bild 1 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 5, Bild 2 von 3 2008 BMW 335xi Blower Motor Replacement: Schritt 5, Bild 3 von 3
    • There is only one connecter that needs to be disconnected to remove the blower motor. This connector is black with two red/orange wires going into it.
    • Pinch the connector on the top and bottom and pull it out to remove it.
  6. 2008 BMW 335xi Blower Motor Replacement: Schritt 6, Bild 1 von 2 2008 BMW 335xi Blower Motor Replacement: Schritt 6, Bild 2 von 2
    • Pull down on the tab towards the front of the car and at the same time turn the whole assembly clockwise.
    • Pull the round black assembly out from the vehicle.
    • This is the blower motor assembly!
    • When pulling the blower motor out, be careful not to drop it on yourself.
Abschluss
To reassemble your blower motor, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S3-G11, Saloman Spring 2021 Mitglied von UMass Dartmouth, Team S3-G11, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G11
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 121
Insgesamt: 3,564
