Einleitung
This repair guide covers replacing the BMW 335xi blower motor at home with just a couple of common hand tools. Blower motors can break for many reasons such as old age, failed bearings, or electrical issues.
You will start by disconnecting the car battery and then proceed through the glove box to the blower motor. To follow these steps you will need a T20 Torx Screwdriver, a 10mm Socket, and a 3/8” drive ratchet. The guide will take you through 6 steps to remove the blower motor. These same steps will be followed in reverse order to install the new blower motor.
Was du brauchst
Put the passenger seat all the way back to create as much room as possible.
Remove any objects from the floor of the passenger seat so that you have a clean workspace.
Remove the panel on the right side of the trunk to expose the battery.
Twist the knob to unlatch the door so that you can remove it.
Use a 10mm socket wrench to loosen the bolt and remove the negative battery terminal.
Then tuck it to the right side and wrap it in a rag.
Remove the two T20 Torx screws located below the glove box.
The panel will drop down as the screws are removed. Pull the panel away slightly.
Disconnect the black cable for the footwell light.
Pull down on the tab towards the front of the car and at the same time turn the whole assembly clockwise.
Pull the round black assembly out from the vehicle.
To reassemble your blower motor, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
