Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Proper visibility when driving is crucial to safe transportation. In rain and snow, suitable windshield wipers will help ensure clear visibility. Use this guide to realign the front windshield wiper arm on a 2008 Subaru Impreza. In a few easy steps, this guide will get you back on the road to safer driving.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. To begin, pop open your hood for best access.
    • To begin, pop open your hood for best access.
  2. There will be a rectangular bolt cover on the end of the wiper arm.
    • There will be a rectangular bolt cover on the end of the wiper arm.
    • To remove this cover, grab each side with your fingers and pull upward.
    • It may help to wedge your fingernails underneath the cover piece.
  3. After removing the bolt cover, you will find the bolt that holds the wiper arm onto the vehicle.
    • After removing the bolt cover, you will find the bolt that holds the wiper arm onto the vehicle.
  4. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  5. Loosen the bolt with the socket wrench just enough to be able to move the arm up and down the windshield.
    • Loosen the bolt with the socket wrench just enough to be able to move the arm up and down the windshield.
    • To loosen with the wrench, place the socket directly on top of the bolt and turn counter clockwise.
  6. Adjust the windshield wiper arm such that it is in the proper resting position.
    • Adjust the windshield wiper arm such that it is in the proper resting position.
  7. There should be approximately 2 inches of space between the bottom of the windshield and the wiper in proper resting position.
    • There should be approximately 2 inches of space between the bottom of the windshield and the wiper in proper resting position.
  8. Once the arm is in correct position, tighten the same bolt at the bottom of the arm to keep the wiper in place.
    • Once the arm is in correct position, tighten the same bolt at the bottom of the arm to keep the wiper in place.
    • To tighten the bolt, place the socket directly on top of the bolt and turn in clockwise position until you are no longer able to turn.
  9. Place the bolt cover back over the bolt and push it down into clipped position.
    • Place the bolt cover back over the bolt and push it down into clipped position.
  10. Close the hood of the vehicle. Your windshield wiper should now be in the correct position.
    • Close the hood of the vehicle. Your windshield wiper should now be in the correct position.
Abschluss
This guide will allow you to adjust both of the front windshield wipers. To realign the passenger side wiper, follow these steps in correct order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Brianna Koski
128 Reputation
1 Anleitung geschrieben
Michigan Tech, Team 1-15, Lauer Spring 2016 Mitglied von Michigan Tech, Team 1-15, Lauer Spring 2016
MTU-LAUER-S16S1G15
1 Mitglied
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 27
Insgesamt: 2,671
