Zum Hauptinhalt wechseln
2009-2015 Toyota Prius Cabin Air Filter Replacement
Was du brauchst
  1. 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 2 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 2 von 2
    • Press the button to open the glove box.
  2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 2, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 2, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 2, Bild 3 von 3
    • Pull hook away from glove box that's located on the right side, near the passenger door.
  3. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 3, Bild 1 von 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 3, Bild 2 von 2
    • On the opposite side of the glove box, apply pressure and pull it towards you to unlatch the left side.
  4. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 4, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 4, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Hold both sides of the glove box.
    • Push the sides in and lift the glove box up while pulling towards you, to remove the glove box from its compartment.
  5. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 5, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 5, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 5, Bild 3 von 3
    • Push in the tab on the right side of the filter cover while pulling it towards you.
  6. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 6, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 6, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 6, Bild 3 von 3
    • Remove the old air filter by lifting it up slightly and pulling it towards you.
  7. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 7, Bild 1 von 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 7, Bild 2 von 2
    • Insert the new cabin air filter by aligning it with the empty space and sliding in.
    • Make sure the arrow on the cabin air filter is pointing in the up direction.
  8. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 8, Bild 1 von 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 8, Bild 2 von 2
    • Insert the left side of the cover back into its slot.
    • Push the right side of the cover back into its clip to secure it.
  9. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 9, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 9, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 9, Bild 3 von 3
    • Align the hooks on the glove box with the square holes located at the bottom of the dash.
    • Push the glove box back into the compartment until the sides click into place.
  10. 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 10, Bild 1 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 10, Bild 2 von 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: Schritt 10, Bild 3 von 3
    • Reinstall the hook on the right side of the glove box by pushing it back over the grey tabs.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UC Davis, Team 2-8, Morris Winter 2023 Mitglied von UC Davis, Team 2-8, Morris Winter 2023
UCD-MORRIS-W23S2G8
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 67
Letzte 30 Tage: 254
Insgesamt: 1,880
