Zum Hauptinhalt wechseln
2009-2014 Ford F-150 Tail Light Replacement
Was du brauchst
  1. 2009-2014 Ford F-150 Tail Light Replacement, Tail Light: Schritt 1, Bild 1 von 1
    • Park on a flat surface with no incline.
    • Open the bed of your truck.
  2. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 2, Bild 1 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 2, Bild 2 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 2, Bild 3 von 3
    • Use a ratchet and 8 mm socket to remove the 2 bolts securing the taillight assembly.
  3. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 3, Bild 1 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 3, Bild 2 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 3, Bild 3 von 3
    • Carefully remove the taillight assembly from the truck by pulling it out towards you.
    • Twist the bulb sockets counterclockwise to remove them from the assembly.
  4. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 4, Bild 1 von 1
    • Set the taillight assembly aside.
  5. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 5, Bild 1 von 2 2009-2014 Ford F-150 Tail Light Replacement: Schritt 5, Bild 2 von 2
    • Remove the bulb you need to replace from the wire harness by pulling it straight out; set it down.
    • Remove the new bulb from the packaging, while being careful not to touch the bulb with your bare hands, and push it into the wire socket.
  6. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 6, Bild 1 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 6, Bild 2 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 6, Bild 3 von 3
    • Turn the bulb sockets clockwise into the assembly to secure them.
  7. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 7, Bild 1 von 2 2009-2014 Ford F-150 Tail Light Replacement: Schritt 7, Bild 2 von 2
    • Carefully push the assembly back into your truck by aligning the plastic tabs.
  8. 2009-2014 Ford F-150 Tail Light Replacement: Schritt 8, Bild 1 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 8, Bild 2 von 3 2009-2014 Ford F-150 Tail Light Replacement: Schritt 8, Bild 3 von 3
    • Replace the two bolts you removed in step 2 with the ratchet and tighten well.
Abschluss
Congratulations on completing our guide to repairing a tail light on a 2014 Ford F150! We hope that this guide will ensure your own safety as well as other drivers around you. We also hope this guide will prevent you from receiving a citation from a police officer, protect your right to repair your belongings, and avoid all of the potential added costs acquired from the repairing process. We thank you for taking the time to read our guide.
Lindsey Lanman
157 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 2-1, Bennett Fall 2023 Mitglied von Sam Houston State, Team 2-1, Bennett Fall 2023
SHSU-BENNETT-F23S2G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 97
Insgesamt: 576
