Zum Hauptinhalt wechseln
2009-2013 Mazda 3 Air Filter Replacement
Was du brauchst
  1. 2009-2013 Mazda 3 Air Filter Replacement, Air Filter: Schritt 1, Bild 1 von 1
    • Correctly identify the air filter for a 2009-2013 Mazda 3.
    • Go to your local car repair shop for help when buying the air filter.
  2. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Identify where the level is to pop the car hod.
  3. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 3, Bild 1 von 1
    • After opening the hood, locate the air filter container.
    • It is located on the south side of the battery.
  4. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 4, Bild 1 von 1
    • Identify where the metal clips are on the side of the air filter container.
    • Unlatch both metal clips on the air filter container to open.
  5. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 5, Bild 1 von 1
    • When the air filter container is open, remove old filter.
    • When the old filter is removed, wipe out container with a wet paper towel.
    • Filter is in there tight, make sure to use a decent amount of force when pulling out.
  6. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Replace new filter.
    • It is a tight squeeze, so make sure the filter is properly fit into the container.
  7. 2009-2013 Mazda 3 Air Filter Replacement: Schritt 7, Bild 1 von 1
    • After you have replaced the new filter, close container and latch both metal hooks to close the container.
Abschluss
You have successfully changed an air filter in any 2009-2013 Mazda 3 model.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 67
Insgesamt: 2,094
