Zum Hauptinhalt wechseln
2009 Honda Civic Window Regulator Replacement
Was du brauchst
  1. 2009 Honda Civic Window Regulator Replacement, Window Regulator: Schritt 1, Bild 1 von 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: Schritt 1, Bild 2 von 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: Schritt 1, Bild 3 von 3
    • Park the vehicle on a level surface and turn off the ignition.
  2. 2009 Honda Civic Window Regulator Replacement: Schritt 2, Bild 1 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 2, Bild 2 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 2, Bild 3 von 3
    • Remove the Phillips screw located behind the door handle.
  3. 2009 Honda Civic Window Regulator Replacement: Schritt 3, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 3, Bild 2 von 2
    • Place a prying tool in the small crevice at the centre of the window controller and pry upwards.
  4. 2009 Honda Civic Window Regulator Replacement: Schritt 4, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the electrical connectors attached to the panel by pressing onto the tab.
  5. 2009 Honda Civic Window Regulator Replacement: Schritt 5, Bild 1 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 5, Bild 2 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 5, Bild 3 von 3
    • Use a prying tool to pry off the door panel.
  6. 2009 Honda Civic Window Regulator Replacement: Schritt 6, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 6, Bild 2 von 2
    • Push downwards on the holder and pull the wire towards yourself.
  7. 2009 Honda Civic Window Regulator Replacement: Schritt 7, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 7, Bild 2 von 2
    • Use a prying tool to remove the two black plugs on the left-hand side and right-hand side of the plastic liner.
  8. 2009 Honda Civic Window Regulator Replacement: Schritt 8, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 8, Bild 2 von 2
    • Remove the connector by pushing onto the tab using a prying tool.
  9. 2009 Honda Civic Window Regulator Replacement: Schritt 9, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the plastic liner.
  10. 2009 Honda Civic Window Regulator Replacement: Schritt 10, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 10, Bild 2 von 2
    • Use a wrench to remove the two bolts located at the left-hand side and right-hand side.
  11. 2009 Honda Civic Window Regulator Replacement: Schritt 11, Bild 1 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 11, Bild 2 von 3 2009 Honda Civic Window Regulator Replacement: Schritt 11, Bild 3 von 3
    • Use the wrench to unscrew the first bolt located at the top of the door in a counterclockwise motion.
    • Use the wrench to unscrew the second bolt located at the bottom of the door in a counterclockwise motion.
  12. 2009 Honda Civic Window Regulator Replacement: Schritt 12, Bild 1 von 2 2009 Honda Civic Window Regulator Replacement: Schritt 12, Bild 2 von 2
    • After removing all four bolts, use your hands to remove the window regulator.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Usman Khan
430 Reputation
2 Anleitungen geschrieben
York University, Team 1-13, O'Regan Winter 2024 Mitglied von York University, Team 1-13, O'Regan Winter 2024
YORK-O'REGAN-W24S1G13
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 89
Insgesamt: 232
