Zum Hauptinhalt wechseln
2009 Kia Sorento Door Handle Replacement
Was du brauchst
  1. 2009 Kia Sorento Door Handle Replacement, Door Handle: Schritt 1, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement, Door Handle: Schritt 1, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement, Door Handle: Schritt 1, Bild 3 von 3
    • Before beginning this project be sure your window is rolled up or the glass will be in the way for later steps.
    • Before you can start removing the side panel, the speaker on the driver side door must be removed. To do this, simply squeeze and it will pop out. There is a little wire that connects the speaker to the car. To detach it there is a little button that can be pushed and it will come loose.
  2. 2009 Kia Sorento Door Handle Replacement: Schritt 2, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 2, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 2, Bild 3 von 3
    • Once the speaker is out, six screws need to be removed to allow the panel to detach from the door.
    • The first four are on opposite ends of the door. One pair is near the door hinge and another pair is located next to the seam.
  3. 2009 Kia Sorento Door Handle Replacement: Schritt 3, Bild 1 von 2 2009 Kia Sorento Door Handle Replacement: Schritt 3, Bild 2 von 2
    • Use a screwdriver to pry out the washers.
  4. 2009 Kia Sorento Door Handle Replacement: Schritt 4, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 4, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 4, Bild 3 von 3
    • Remove the screw securing the door handle.
    • Remove the door handle.
  5. 2009 Kia Sorento Door Handle Replacement: Schritt 5, Bild 1 von 2 2009 Kia Sorento Door Handle Replacement: Schritt 5, Bild 2 von 2
    • Remove the final screw next to the lock and window buttons in a little hole.
  6. 2009 Kia Sorento Door Handle Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool or any other prying tool to remove the panel.
  7. 2009 Kia Sorento Door Handle Replacement: Schritt 7, Bild 1 von 1
    • Detach the wires that control the locks, windows, and lights in the car door.
  8. 2009 Kia Sorento Door Handle Replacement: Schritt 8, Bild 1 von 2 2009 Kia Sorento Door Handle Replacement: Schritt 8, Bild 2 von 2
    • Hold down the little button and pull the wire away from the car.
  9. 2009 Kia Sorento Door Handle Replacement: Schritt 9, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 9, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 9, Bild 3 von 3
    • Detach the two white blocks of wires.
  10. 2009 Kia Sorento Door Handle Replacement: Schritt 10, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 10, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 10, Bild 3 von 3
    • After all the wires are detached and the door panel is set to the side, pull back the plastic seal to gain access to the bolts.
    • You don't need to completely remove it, just enough to fit your hand inside to unscrew the bolts.
  11. 2009 Kia Sorento Door Handle Replacement: Schritt 11, Bild 1 von 2 2009 Kia Sorento Door Handle Replacement: Schritt 11, Bild 2 von 2
    • There are two bolts behind the plastic you just pulled back and one to the outer side of the car door behind a little plastic cover.
  12. 2009 Kia Sorento Door Handle Replacement: Schritt 12, Bild 1 von 2 2009 Kia Sorento Door Handle Replacement: Schritt 12, Bild 2 von 2
    • Use a socket wrench with a 10mm attachment to loosen the bolts. To remove the bolts on the inside of the door, just loosen the bolts with the socket wrench and then use your hands to remove it completely.
  13. 2009 Kia Sorento Door Handle Replacement: Schritt 13, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 13, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 13, Bild 3 von 3
    • Remove the door handle from the vehicle.
  14. 2009 Kia Sorento Door Handle Replacement: Schritt 14, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 14, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 14, Bild 3 von 3
    • Push the semi-circle piece away from the metal rod and remove the metal rod.
  15. 2009 Kia Sorento Door Handle Replacement: Schritt 15, Bild 1 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 15, Bild 2 von 3 2009 Kia Sorento Door Handle Replacement: Schritt 15, Bild 3 von 3
    • Now that the old door handle is fully detached from the car you can now put in your replacement part.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jack Wilson
457 Reputation
1 Anleitung geschrieben
2 Kommentare
I got up to "remove the white blocks (electrical) from the door panel". I couldn't get them out. Any suggestions?
Richard Waller - Antwort
I'm about to do this 2009 Kia Sorento LX both driver and passenger front handle replacement next weekend. I hope yours went well, wish me luck!!
MoniB -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 50
Insgesamt: 3,717
