Zum Hauptinhalt wechseln
2009 Subaru Impreza WRX Rear Door Panel Replacement
Was du brauchst
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: Schritt 1, Bild 1 von 1
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 3, Bild 1 von 1
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 5, Bild 1 von 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 5, Bild 2 von 2
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 6, Bild 1 von 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 6, Bild 2 von 2
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 7, Bild 1 von 1
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 8, Bild 1 von 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 9, Bild 1 von 1
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 10, Bild 1 von 1
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: Schritt 11, Bild 1 von 1
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
Abschluss
Joseph Coplon
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 8-3, Regan Spring 2015 Mitglied von Cal Poly, Team 8-3, Regan Spring 2015
CPSU-REGAN-S15S8G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 2,444
