Zum Hauptinhalt wechseln
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 1 von 1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 2, Bild 1 von 2 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 2, Bild 2 von 2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 3, Bild 1 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 3, Bild 2 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 4, Bild 1 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 4, Bild 2 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 4, Bild 3 von 3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 5, Bild 1 von 1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 6, Bild 1 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 6, Bild 2 von 3 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 6, Bild 3 von 3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 7, Bild 1 von 2 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 7, Bild 2 von 2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 8, Bild 1 von 2 2010-2014 BMW X6 Tail Light Bulb Replacement: Schritt 8, Bild 2 von 2
    • Close trunk and admire your hard work!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
CSU Los Angeles, Team 11-99, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-99, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G99
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
Good job There
Jose Alberto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 82
Insgesamt: 2,238
