Zum Hauptinhalt wechseln
2010-2014 Dodge Ram 1500 Headlight Replacement
Was du brauchst
Angehängtes Dokument
  1. 2010-2014 Dodge Ram 1500 Headlight Replacement, Headlight: Schritt 1, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement, Headlight: Schritt 1, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement, Headlight: Schritt 1, Bild 3 von 3
    • Caution: Before beginning, make sure your truck is turned off and the engine has cooled.
    • Pull the hood latch under the driver's steering wheel.
    • Positioning yourself at the hood of the truck in front of the logo, put two fingers under the hood to find the latch.
    • Push the latch to the left, hold, and lift the hood.
    • Use the support rod to keep the hood propped open.
  2. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 2, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 2, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 2, Bild 3 von 3
    • Pull the four tabs around the plastic cover above the grille to reveal the four bolts underneath.
  3. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 3, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 3, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 3, Bild 3 von 3
    • Pop up each of the four clips.
  4. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 4, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 4, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 4, Bild 3 von 3
    • Remove the 4 bolts located along the top of the grill with the appropriately sized socket wrench.
  5. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 5, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 5, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 5, Bild 3 von 3
    • Carefully pull out and up on the grill.
    • It will make a scary sound like you snapped it but it’ s okay, nothing broke.
  6. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 6, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 6, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 6, Bild 3 von 3
    • Remove the two bolts on the inner side of the headlight's head with the appropriately sized socket wrench.
  7. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 7, Bild 1 von 2 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 7, Bild 2 von 2
    • Pull the light towards you to get the lights out.
  8. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 8, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 8, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 8, Bild 3 von 3
    • Turn the circular seals on the headlight counter-clockwise to release the cap.
    • There will be one on top (normal headlight) and one on the bottom (brights).
    • If you are looking on the inside of the headlight cover you will see a wire connected to the headlight.
    • Detach the cable by lifting up the tab on the top and pulling.
  9. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 9, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 9, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 9, Bild 3 von 3
    • Unscrew and dispose of the old lightbulb and screw the new one in.
  10. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 10, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 10, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 10, Bild 3 von 3
    • Plug the wire back into the new headlight to give it power.
    • Reseal the circular cap on the headlight by turning it clockwise.
    • Place the whole headlight back into its original spot.
  11. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 11, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 11, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 11, Bild 3 von 3
    • Put the headlight in the original slot. Push in towards the truck until you feel it click into place.
    • Replace the two bolts on the inner side of the headlight.
  12. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 12, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 12, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 12, Bild 3 von 3
    • Snap the grill back in by pushing the two bottom corners in and then pushing in from the middle.
    • Just as in step 4 and 5, this will cause a scary sound.
  13. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 13, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 13, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 13, Bild 3 von 3
    • Replace the four bolts along the top of the grill to secure the grill back in place.
    • Shake the grill to make sure it's fully secured.
  14. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 14, Bild 1 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 14, Bild 2 von 3 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 14, Bild 3 von 3
    • Push the four button clips on the engine cover into the corresponding holes.
  15. 2010-2014 Dodge Ram 1500 Headlight Replacement: Schritt 15, Bild 1 von 1
    • Shut the hood, you're all done!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Angehängte Dokumente
Texas Tech, Team S3-G7, Cowan Spring 2021 Mitglied von Texas Tech, Team S3-G7, Cowan Spring 2021
TTU-COWAN-S21S3G7
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 37
Letzte 30 Tage: 254
Insgesamt: 14,126
