Einleitung
This guide will detail how to change the coolant reservoir in a 2014 Ford Mustang. A coolant reservoir will need to be replaced if there are any leaks to prevent the engine from overheating and causing serious and expensive damage.
There is some concern about working with antifreeze coolants due to their high potential to be toxic when inhaled and/or absorbed through the skin. The main ingredient in the coolant that causes this potential toxicity is ethylene glycol. This chemical compound can cause mild respiratory tract, skin and eye irritation. This can be easily avoided by wearing the proper personal protective equipment such as goggles, masks, gloves and other garments that could protect you from excessive exposure to the chemical.
Was du brauchst
Disconnect the negative cable from the car battery to eliminate the risk of being shocked while working. Allow car to sit for 5 minutes to make sure leftover power is discharged completely.
Using an adjustable wrench or 12mm combination wrench, remove the bolts that keep the reservoir attached to engine.
Using pliers, an adjustable wrench, or by hand, carefully remove the hose clamps that connect the coolant hoses to the reservoir and allow residual coolant to drain into a drip pan or other sealable container.
Allow excess coolant to drain from the radiator, hoses, and old reservoir to drain into a drip pan or other sealable container.
Attach and clamp coolant hoses to new reservoir. Make sure they are secured tightly and that no gaps are visible.
Align reservoir into the correct position and reattach the bolts to the reservoir. Make sure it is held down tightly.
Fill the new reservoir with coolant to maximum level indicated by the markings on the side of the plastic.
Reattach the negative cable to the battery and ensure the connection is secure. Check to see if the battery provides power by turning the headlights on.
In case something breaks or an issue with the car arises, do not drive and contact a mechanic.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
