Zum Hauptinhalt wechseln
2010-2014 Ford Mustang Headlight Replacement
Was du brauchst
  1. 2010-2014 Ford Mustang Headlight Replacement, Headlight Bulb: Schritt 1, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement, Headlight Bulb: Schritt 1, Bild 2 von 2
    • Pull the release lever firmly to release the latch securing the hood.
  2. 2010-2014 Ford Mustang Headlight Replacement: Schritt 2, Bild 1 von 1
    • Raise the hood of the car and connect the car hood prop to the correct place.
  3. 2010-2014 Ford Mustang Headlight Replacement: Schritt 3, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the six 19 mm plastic screws holding the protective plastic piece in place.
  4. 2010-2014 Ford Mustang Headlight Replacement: Schritt 4, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement: Schritt 4, Bild 2 von 2
    • Locate the headlight casing cap in the front of the engine compartment near the headlight unit that is out.
    • Twist the cap counter-clockwise firmly and lift it up to remove it.
  5. 2010-2014 Ford Mustang Headlight Replacement: Schritt 5, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement: Schritt 5, Bild 2 von 2
    • Twist and pull the bulb gently to dislodge it from the headlight casing.
  6. 2010-2014 Ford Mustang Headlight Replacement: Schritt 6, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement: Schritt 6, Bild 2 von 2
    • Pinch the tabs near the base of the bulb together and pull the bulb from its socket.
  7. 2010-2014 Ford Mustang Headlight Replacement: Schritt 7, Bild 1 von 2 2010-2014 Ford Mustang Headlight Replacement: Schritt 7, Bild 2 von 2
    • Grab the new bulb slide it into the socket firmly to secure it between the tabs.
Abschluss
To reassemble your device, follow these instructions in reverse order. Once reassembled, test the new bulb to ensure that is safe to drive with. Good luck and we hope you have no further problems!
Blake
145 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 1-9, Bennett Fall 2023 Mitglied von Sam Houston State, Team 1-9, Bennett Fall 2023
SHSU-BENNETT-F23S1G9
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 99
Insgesamt: 557
