Einleitung
Headlights are one of the most important parts of a car when it comes to the safety of drivers. When a headlight goes out, it is not only an inconvenience, but also a danger to all drivers on the road at the time. Luckily, however, if it is simply a bulb that has gone out, it is a simple and quick replacement. In this guide, we are going to show you step-by-step how to efficiently and quickly replace the headlight bulb of a 2010-2014 model Ford Mustang. Follow along with us and we will have you driving safely again shortly!
Was du brauchst
Pull the release lever firmly to release the latch securing the hood.
Use a Phillips #2 screwdriver to remove the six 19 mm plastic screws holding the protective plastic piece in place.
Locate the headlight casing cap in the front of the engine compartment near the headlight unit that is out.
Twist the cap counter-clockwise firmly and lift it up to remove it.
Pinch the tabs near the base of the bulb together and pull the bulb from its socket.
Grab the new bulb slide it into the socket firmly to secure it between the tabs.
To reassemble your device, follow these instructions in reverse order. Once reassembled, test the new bulb to ensure that is safe to drive with. Good luck and we hope you have no further problems!
