Einleitung
This guide will provide step-by-step instructions to replace the Central Electronic Control Unit (ECU) fuse in your 2010-2013 Volkswagen Golf. The Central ECU is responsible for the maths used in your fuel mixture, your engine timing, and the general wellness of your car's engine. If the troubleshooting guide hasn’t been able to help you, this guide will take you through the repair.
Make sure to turn off your vehicle and disconnect your battery to prevent any shorting of electronics or further damage to your car's electrical system before you begin.
Locate the vehicle's fusebox. On this model of the Golf, it will be located on the interior panel of the dashboard on the driver's side of the car.
On the back of the fuse box's cover panel, there will be a fuse puller attached. Locate this piece prior to removing any of the vehicle's fuses.
Identify and remove the blown fuse: Each fuse piece is labeled. The correct fuse for the ECU is number 24. Your vehicle's manual will also include a diagram of the fuse box's layout.
Using the fuse puller, place the new fuse into the empty slot for fuse 24, and ensure that the replacement fuse fits firmly.
Place the puller on the back of the panel cover after the new fuse has been installed.
Align the panel cover with the frame of the dashboard, and gently apply pressure on the cover until it clicks into place. Confirm that the piece is firmly installed.
Insert the key into the vehicle's ignition, and place the vehicle into accessory mode. Confirm that the vehicle's lights turn on and function as normally.
If the fuse is working, congratulations! If you're still having trouble, try asking around here to get some help.
4 weitere Personen haben diese Anleitung absolviert.
