Einleitung
The following guide will walk through steps necessary to replace headlights on a 2010 Chevrolet Aveo and all similar model years. You may find it necessary to complete this replacement if you have noticed your headlight dimming after many years of use. This guide will help to replace these dim headlights so you remain safe on the road. This replacement is accomplished by removing the headlight housing from the vehicle for ease of access.
Was du brauchst
Pull the hood release lever underneath the steering wheel to release hood lock.
Release the lever under the hood and lift it up to release the hood completely. Simultaneously lift the hood and prop it up with the hood prop securing it in an open position.
Use 10 mm socket to remove three bolts securing headlight housing.
Carefully pull the headlight housing away from the vehicle until you can easily access the rear housing.
Remove the outer gasket and set it aside for reinstallation.
Disconnect the clip from the headlight mount.
Remove the headlight so the housing is empty and ready for replacement.
Start the new headlight installation by placing the headlight mount into the headlight housing and secure it with the clip by pinching the ends together and hooking it under the edges of the housing.
Slide the outer gasket over the headlight mount ensuring the "top" is properly oriented.
Line up the grooves on the new headlight with the headlight harness.
Insert the headlight and rotate it to lock it in place.
Reinstall the headlight housing by setting the housing back into place and lining up the bolt holes.
Replace the three bolts using a 10mm socket and ratchet.
Reattach the headlight connector.
Repeat steps 3 through 9 for other headlight. Ensure proper working order upon completion.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
