Einleitung
This guide shows you how to replace the air filter on a 2010 Ford F-250 Super Duty pickup truck.
Air filters protect your engine from contaminants, letting it breathe easier. Changing your air filter helps enhance performance and efficiency as well as extend your engine's life.
If you drive on dirty or dusty roads or notice a drop in performance or gas mileage you may need to replace it more often. Changing your air filter is one of the simplest and least expensive maintenance projects you can undertake.
Was du brauchst
Loosen hose clamp holding air filter to air filter assembly using flathead screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
