Einleitung
Replace the tail light bulbs in a 2010 GMC Sierra. Tail lights are for telling other drivers that a vehicle is stopping. Ensuring proper tail light operation is important, and so is doing this process correctly. Make sure to have a replacement tail light bulb, some latex gloves, a 10mm wrench, and a Philips head #2 screwdriver before beginning.
Was du brauchst
Open the hood of the truck.
Using the 10mm wrench, loosen and remove the 1-3/4" bolt securing the cable.
Pull the cable from the battery.
Using the Philips screwdriver, remove the two 4.8x16mm screws securing the housing.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Is there a way to get these things not to get moisture inside the backup bulb area?
