Einleitung
Your car mirrors are essential to the safety of you and others in your car. Keeping them in good shape and undamaged is always helpful, but sometimes, life happens, and you need to replace the mirror(s). So, in this guide, I will show you how to quickly and easily change your mirror with no experience needed—and it's a lot cheaper than going to a mechanic. This guide is for a Scion 2010 TC Coupe but any year below this one can also be used as well.
Was du brauchst
Go to the side where you are going to work and remove the protective cover with your hands to reveal three bolts.
Attach a 10mm socket to a ratchet.
Place the ratchet on one of the bolts and start rotating the ratchet down then up to loosen each nut. After each nut is loose remove them by hand.
Push down on the white tab and pull on the cable at the same time to free the mirror.
Remove the mirror from the door and insert the new mirror.
Attach the nuts onto each bolt by hand. Insert the cable into the new mirror until you hear a click.
Switch your ratchet back to the tightening setting and rotate up then back down to tighten each nut.
Use the ratchet to tighten each nut until it stops moving.
Put the protective cover onto its original spot.
Line up the cover and press firmly it on a few times until you hear it click.
Adjust the mirror as needed and you will be all set to drive again!
