Zum Hauptinhalt wechseln
2010 Toyota Corolla Headlight Replacement
Was du brauchst
  1. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: Schritt 1, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: Schritt 1, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: Schritt 1, Bild 3 von 3
    • Find the handle to open the Bonnet. It will be located at the bottom left-hand side of the driver's seat.
    • Pull the handle towards yourself and you will see the bonnet pop up a small bit.
  2. 2010 Toyota Corolla Headlight Replacement: Schritt 2, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 2, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 2, Bild 3 von 3
    • Move the handle to the left in order to release the hood completely.
    • Locate the black stick and insert it in the bonnet hole.
  3. 2010 Toyota Corolla Headlight Replacement: Schritt 3, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 3, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 3, Bild 3 von 3
    • On the left, upper side of the hood, you can locate the bulb
    • Twist it halfway counter-clockwise and pull it out.
  4. 2010 Toyota Corolla Headlight Replacement: Schritt 4, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 4, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 4, Bild 3 von 3
    • Push the hook down to detach the bulb from the wire.
  5. 2010 Toyota Corolla Headlight Replacement: Schritt 5, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 5, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 5, Bild 3 von 3
    • Replace it with a new bulb and turn it clockwise to have it fixed permanently.
    • If the bulb is not turned clockwise, the bulb will come off and become loose again.
  6. 2010 Toyota Corolla Headlight Replacement: Schritt 6, Bild 1 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 6, Bild 2 von 3 2010 Toyota Corolla Headlight Replacement: Schritt 6, Bild 3 von 3
    • Turn on the lights to make sure both headlights are working :)
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team 2-12, O'Regan Winter 2022 Mitglied von York University, Team 2-12, O'Regan Winter 2022
YORK-O'REGAN-W22S2G12
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 93
Insgesamt: 2,577
