Zum Hauptinhalt wechseln
2011-2018 BMW 3-Series Auxiliary Turn Signal Indicator Lamp Replacement
Was du brauchst
  1. 2011-2018 BMW 3-Series Auxiliary Turn Signal Indicator Lamp Replacement, Auxiliary Turn Signal Indicator Lamp: Schritt 1, Bild 1 von 1
    • Gently use a car trim tool to pop the mirror glass off its central holder. You shouldn't need to detach the cables to it, as it can just rest against the window after removal.
  2. 2011-2018 BMW 3-Series Auxiliary Turn Signal Indicator Lamp Replacement: Schritt 2, Bild 1 von 1
    • There are three plastic clips holding the front wing mirror trim in place. Squeeze the plastic 'legs' of the clips to release and then push forward. With a little bit of persuasion, you should then be able to slide the plastic cover off.
  3. 2011-2018 BMW 3-Series Auxiliary Turn Signal Indicator Lamp Replacement: Schritt 3, Bild 1 von 1
    • Use a T10 Torx driver to remove the three T10 Torx screws along the bottom of the inside of the wing mirror, to loosen the bottom of the wing mirror casing.
  4. 2011-2018 BMW 3-Series Auxiliary Turn Signal Indicator Lamp Replacement: Schritt 4, Bild 1 von 1
    • Loosen the bottom half of the wing mirror, and slide the indicator lamp unit out. With a litte bit of persuasion, the cable connect should just pull out. Replace the old indicator with your new one, and reconnect the cable.
Abschluss
To reassemble, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
Kit Marsden
520 Reputation
2 Anleitungen geschrieben
1 Kommentar zur Anleitung
привет. напиши, как восстановить суппорта.
Привалов Евгений - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 102
Letzte 30 Tage: 611
Insgesamt: 5,024
