Zum Hauptinhalt wechseln
2011-2017 Hyundai Accent Brake Light Replacement
  1. 2011-2017 Hyundai Accent Brake Light Replacement, Brake Light: Schritt 1, Bild 1 von 1
    • Open the trunk of the vehicle.
  2. 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 2, Bild 1 von 3 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 2, Bild 2 von 3 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 2, Bild 3 von 3
    • View the side flap for whichever side has the dead bulb. (This is the left side view.)
    • Pull the flap up and locate the brake light.
    • The flap may need some extra force to open because the cutouts are typically not cut all the way through.
  3. 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 3, Bild 1 von 2 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 3, Bild 2 von 2
    • Twist the socket counterclockwise to gain access to the brake light.
  4. 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 4, Bild 1 von 2 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 4, Bild 2 von 2
    • Push down slightly and twist the bulb counterclockwise to remove the dead bulb.
    • Pay attention to the protrusions located on the bottom of the bulb. You will need to align these protrusions with the socket when inserting the new bulb.
  5. 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 5, Bild 1 von 2 2011-2017 Hyundai Accent Brake Light Replacement: Schritt 5, Bild 2 von 2
    • Insert the new bulb into the socket and twist the bulb clockwise to secure it into place.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
The Other Guy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 67
Letzte 30 Tage: 316
Insgesamt: 14,649
