Einleitung
If your 2013 Hyundai Accent brake light is no longer working, use this guide to replace the light.
The brake light alerts other drivers of whether you are slowing down or stopping the vehicle. It is important to ensure that you have a working brake light because it is a ticketable offense and for safety reasons.
Before using this guide, make sure to turn the car off and to purchase a replacement bulb (Model: Sylvania 2357LL).
View the side flap for whichever side has the dead bulb. (This is the left side view.)
Pull the flap up and locate the brake light.
Push down slightly and twist the bulb counterclockwise to remove the dead bulb.
Pay attention to the protrusions located on the bottom of the bulb. You will need to align these protrusions with the socket when inserting the new bulb.
Insert the new bulb into the socket and twist the bulb clockwise to secure it into place.
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
