Einleitung
Nowadays air conditioner filters have an important role in our lives. This is because it can help us to trap any virus particles. Therefore it is recommended to acquire a higher-efficiency air filter. This guide will teach you how to change the air conditioner filter of your car. To get started you will need the model of the filter necessary for your vehicle and basic knowledge on how to use a screwdriver.
Was du brauchst
Locate the filter (it should be located in the lower part of the glove compartment)
Remove two 9.5 mm slotted head screws with the slotted screwdriver.
Remove the cover. Put your fingers behind the cover and carefully little by little remove it.
The piece of plastic that is sticking out (where my thumb is placed) push it to the right.
Once it is unlocked, remove the lid.
Take out the filter carefully (it may contain dust) and replace it with a new filter.
3 weitere Personen haben diese Anleitung absolviert.
