Zum Hauptinhalt wechseln
2011-2016 Ford Super Duty Tail Light and Bulbs Replacement
Was du brauchst
    1. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: Schritt 1, Bild 1 von 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement, Tail Light and Bulbs: Schritt 1, Bild 2 von 2
      • Locate the two 8 mm screws that attach the taillight housing to the vehicle.
      Frag FixBot
      Kommentar hinzufügen
    2. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 2, Bild 1 von 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 2, Bild 2 von 2
      • Using a socket and ratchet wrench, remove the two screws facing the inside of the bed that you located in Step 1.
      Frag FixBot
    3. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 3, Bild 1 von 2 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 3, Bild 2 von 2
      • Pull the light housing outward at an angle away from the truck.
      Frag FixBot
    4. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 4, Bild 1 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 4, Bild 2 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 4, Bild 3 von 3
      • Twist the light socket in a counterclockwise motion to remove the bulbs.
      Frag FixBot
    5. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 5, Bild 1 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 5, Bild 2 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 5, Bild 3 von 3
      • Insert a new bulb.
      • Place the light bulb socket back in the hole and turn clockwise until it's locked in place.
      Frag FixBot
    6. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 6, Bild 1 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 6, Bild 2 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 6, Bild 3 von 3
      • Line up the taillight housing with the holes and guides, and push it into place.
      Frag FixBot
    7. 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 7, Bild 1 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 7, Bild 2 von 3 2011-2016 Ford Super Duty Tail Light and Bulbs Replacement: Schritt 7, Bild 3 von 3
      • Use a socket and ratchet wrench to tighten the screws back into the taillight housing.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 120
Insgesamt: 7,384
