Einleitung
A working brake light is not only essential for the safety of a motor vehicle, but it is also the law. This guide is designed for changing a 2011-2015 KIA Optima’s rear brake light. Follow the instructions carefully as the process deals with glass and electricity. Be absolutely sure to remove the battery connector before changing the bulb and to handle the replacement with latex gloves.
Werkzeuge
Ersatzteile
Open the trunk and locate the tail light compartment behind the rear wheel well.
This guide will serve for both brake lights.
Squeeze and pull back on the felt-like access panel to expose the tail light assembly.
Squeeze down on the top tab of the battery connector. Then, pull the connector out.
The grey brake light holder is connected to three wires. (Pink, Green, and Black as displayed)
Twist the holder counter-clockwise using the two protruding tabs. Pull out the holder once unlocked.
Gently push the bulb in and simultaneously twist clockwise to lock it into the holder.
To reassemble your car, follow these instructions in reverse order.
2 weitere Nutzer haben diese Anleitung absolviert.
