Einleitung
This guide provides the steps required to replace the headlight bulbs of a 2011-2015 Kia Optima LX/EX/SX.
Dim or burnt-out headlights are a safety risk to you and others, and it can be illegal to drive in the dark without them. Replacing the headlights allows you to remove non-functioning headlights and replace them with working ones or replace dim lights with significantly brighter lights, enabling you to see clearer while driving at night.
Before beginning this repair, turn off the car, engage the parking brake, and disconnect the battery.
Was du brauchst
Pull the hood lever inside the driver's side footwell.
Pull the hidden latch under the hood.
While pulling the latch, lift up on the hood.
Rotate the bulb assembly counter-clockwise.
Remove the bulb assembly to access the wiring and harness.
Squeeze the fins on either size of the bulb connector.
Pull the bulb away from the connector.
Align and insert the now-connected bulb into the headlight slot.
Turn the bulb clockwise to lock it into place.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
