Einleitung
If your interior map light is not working in your 3rd Gen Kia Optima (2011-2015), this guide will show you how to replace the mini LED bulb located within the map light console.
Before using this guide, make sure that the vehicle is powered off completely.
Was du brauchst
Wedge the tip of the prying tool between the lens and the console.
Gently pry the lens off of the console.
Push the lens into the console. When you hear a click, the lens has been attached properly.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
