Einleitung
This guide shows readers how to replace the indicator light bulb for a 2011 Ford Fiesta. This bulb signals other drivers while making lane changes on the road. The frequent use of the indicator bulb can cause the fuse to blow, or at times the bulb will burn out. In this guide, I will provide steps needed to replace the bulb. I also want to encourage readers to fix simple car repairs and hopefully use the skills gained in the other parts of their lives. People spend thousands of dollars on car repairs each year. I want to show readers that a mechanical background is sometimes not needed and that people can save a lot of money by using this guide.
Was du brauchst
Make sure there is space to insert fingers. If not, repeat step 2.
Push the yellow hood release to the left to open the hood.
Lift the hood with one hand and place the strut upright in the correct position.
Place strut in the hole to the left of the hood.
Carefully remove the headlight.
Gently pull up and towards your body.
Set the headlight to the side.
Press both ends of the bulb container to remove the electrical connector from the bulb container.
Pull out the bulb from the headlight.
Press both ends of the electrical connector to separate from the bulb container.
Eine weitere Person hat diese Anleitung absolviert.
