Zum Hauptinhalt wechseln
2011 Ford Fiesta Headlight Replacement
Was du brauchst
    1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: Schritt 1, Bild 1 von 1
      • Park the car where you have room to work.
      • Check that the hand brake is on and the engine is off.
      • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
      • Ensure that the car has rested for at least 30 minutes.
      Frag FixBot
      Kommentar hinzufügen
    2. 2011 Ford Fiesta Headlight Replacement: Schritt 2, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 2, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 2, Bild 3 von 3
      • Pull the hood release under the driver's dashboard towards you.
      Frag FixBot
    3. 2011 Ford Fiesta Headlight Replacement: Schritt 3, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 3, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 3, Bild 3 von 3
      • Make sure there is space to insert fingers. If not, repeat step 2.
      • Push the yellow hood release to the left to open the hood.
      Frag FixBot
    4. 2011 Ford Fiesta Headlight Replacement: Schritt 4, Bild 1 von 2 2011 Ford Fiesta Headlight Replacement: Schritt 4, Bild 2 von 2
      • Lift the hood with one hand and place the strut upright in the correct position.
      • Place strut in the hole to the left of the hood.
      Frag FixBot
    5. 2011 Ford Fiesta Headlight Replacement: Schritt 5, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 5, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 5, Bild 3 von 3
      • Use a flathead screwdriver to loosen the lower retained screw.
      • Collect the screws and store them somewhere safe.
      Frag FixBot
    6. 2011 Ford Fiesta Headlight Replacement: Schritt 6, Bild 1 von 2 2011 Ford Fiesta Headlight Replacement: Schritt 6, Bild 2 von 2
      • Remove the upper retained screw.
      • Store the screw in a safe place.
      Frag FixBot
    7. 2011 Ford Fiesta Headlight Replacement: Schritt 7, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 7, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 7, Bild 3 von 3
      • Carefully remove the headlight.
      • The headlight is attached to three electrical connectors.
      • Gently pull up and towards your body.
      • Set the headlight to the side.
      Frag FixBot
    8. 2011 Ford Fiesta Headlight Replacement: Schritt 8, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 8, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 8, Bild 3 von 3
      • Press both ends of the bulb container to remove the electrical connector from the bulb container.
      Frag FixBot
    9. 2011 Ford Fiesta Headlight Replacement: Schritt 9, Bild 1 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 9, Bild 2 von 3 2011 Ford Fiesta Headlight Replacement: Schritt 9, Bild 3 von 3
      • Pull out the bulb from the headlight.
      • Press both ends of the electrical connector to separate from the bulb container.
      Frag FixBot
    10. 2011 Ford Fiesta Headlight Replacement: Schritt 10, Bild 1 von 1
      • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
      • Hold the black part of the bulb.
      • The bulb might break, so be sure to wear gloves and protective glasses.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
York University, Team S2-G13, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G13, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G13
1 Mitglied
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 27
Letzte 30 Tage: 99
Insgesamt: 9,704
