Zum Hauptinhalt wechseln
2011 Ford Focus Air Conditioning Refrigerant Replacement
Was du brauchst
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: Schritt 1, Bild 1 von 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: Schritt 1, Bild 2 von 3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: Schritt 1, Bild 3 von 3
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 2, Bild 1 von 1
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 3, Bild 1 von 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 3, Bild 2 von 2
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 4, Bild 1 von 1
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 5, Bild 1 von 2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: Schritt 5, Bild 2 von 2
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sujan
130 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 109
Letzte 30 Tage: 357
Insgesamt: 4,693
