Zum Hauptinhalt wechseln
2011 Honda Pilot Overhead Lightbulb and Switch Replacement
Was du brauchst
  1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: Schritt 1, Bild 1 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: Schritt 1, Bild 2 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: Schritt 1, Bild 3 von 3
    • Use a plastic pry tool to detach the light cover.
    • Be careful not to pry too hard, otherwise you risk breaking the cover.
  2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 2, Bild 1 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 2, Bild 2 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 2, Bild 3 von 3
    • Use the pry tool to the light and attach the new one inside of the clamps that hold the bulb.
    • Repeat the same process for the left side bulb.
  3. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 3, Bild 1 von 2 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws inside of the unit using a Phillips #00 screwdriver.
  4. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 4, Bild 1 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 4, Bild 2 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 4, Bild 3 von 3
    • Open the sunglasses case.
    • Use a Phillips #00 screwdriver to remove the screws.
    • Keep track of the screws. The front ones are silver, while the black ones inside the sunglasses case are black.
  5. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 5, Bild 1 von 1
    • After the screws come undone, this is what the unit should look like.
  6. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 6, Bild 1 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 6, Bild 2 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 6, Bild 3 von 3
    • Press down on the four cable clamps to detach them.
    • Do not use the wires to pull them out. You may risk damaging the cables connecting to the unit.
  7. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 7, Bild 1 von 1
    • After detaching all cables, the unit should look like this and come right off.
  8. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 8, Bild 1 von 2 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 8, Bild 2 von 2
    • Insert a plastic pry tool inside this little slot. Once you do, flick up to release this middle part from the unit.
  9. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 9, Bild 1 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 9, Bild 2 von 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: Schritt 9, Bild 3 von 3
    • Insert a prying tool into the button switch. Then push out to flick out the button.
    • Once the button has fallen out, insert the new switches by sliding them back where the old ones were.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Nicholas Sisneros
169 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 3-1, Harris Fall 2024 Mitglied von CSU Los Angeles, Team 3-1, Harris Fall 2024
CSULA-HARRIS-F24S3G1
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 55
Insgesamt: 479
