Einleitung
Replacing a 2011 Jeep Liberty hood is a moderately simple task, requiring only a single tool. It is recommended to have two people complete the replacement, though it is not a requirement. There are no special skills required for this replacement. Replacing the hood is usually a cosmetic choice but may be needed if the hood is misshapen and will not longer function with the vehicle.
Was du brauchst
Open the hood of the Jeep by pulling the hood latch. This is placed right next to the driver's seat and to the left of the brake pedal.
Notice a latch located above the car's grill after popping the hood. Lift the hood by releasing the latch. After lifting the hood, notice a movable latch just above the wiper fluid container. There is a specific hole on the left side of the hood where you can hook the latch.
Identify the four bolts which can be seen towards the extreme left (2 bolts) and extreme right (2 bolts) underneath the hood.
