Zum Hauptinhalt wechseln
2011 Scion Tc Blower Motor Replacement
Was du brauchst
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: Schritt 1, Bild 1 von 1
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: Schritt 4, Bild 1 von 2 2011 Scion Tc Blower Motor Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: Schritt 5, Bild 1 von 2 2011 Scion Tc Blower Motor Replacement: Schritt 5, Bild 2 von 2
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: Schritt 6, Bild 1 von 1
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: Schritt 7, Bild 1 von 1
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
Abschluss
Jose Ruvalcaba
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 13-13, Harris Spring 2022 Mitglied von CSU Los Angeles, Team 13-13, Harris Spring 2022
CSULA-HARRIS-S22S13G13
1 Mitglied
Ein Kommentar
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 1,141
