Einleitung
This guide explains how to replace a 2011 Scion Tc 2011 blower motor. If your vehicle's HVAC doesn’t blow air at all, then it can be your blower motor. The blower motor turns the blower fan, which sends fresh air to your vehicle.
This replacement is fairly straightforward. This repair is needed for every 2011 Scion Tc, because blower motor plays an important role to keep drivers cool or warm. It's a crucial part of the heating and cooling systems in a 2011 Scion Tc.
Was du brauchst
Locate your blower motor. Your blower motor should be below the glovebox.
Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
Ein Kommentar
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
