Zum Hauptinhalt wechseln
2011 Volkswagen Eos Headlight Bulb Replacement
Was du brauchst
  1. 2011 Volkswagen Eos Headlight Bulb Replacement, Headlight LED: Schritt 1, Bild 1 von 1
    • Open the hood latch.
  2. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 2, Bild 1 von 1
    • Pull the lever up to unlatch the hood.
  3. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 3, Bild 1 von 1
    • Pull up the retainer clip, pushing up towards the front of the car.
  4. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic cover and place it off to the side.
  5. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the bulb casing.
  6. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 6, Bild 1 von 1
    • Pull the non-functional halogen bulb from the casing. This may take considerable force.
    • Be sure to have nylon gloves for this step!
  7. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 7, Bild 1 von 1
    • Insert the new halogen bulb into the casing.
  8. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 8, Bild 1 von 1
    • Insert bulb casing back into the socket.
  9. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 9, Bild 1 von 1
    • Place the plastic cover back into the clips.
  10. 2011 Volkswagen Eos Headlight Bulb Replacement: Schritt 10, Bild 1 von 1
    • Close retainer clip by pushing down towards the bottom of the car to secure.
Abschluss
With the completion of the guide, your headlight LED should be working.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam Malmquist
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 124
Insgesamt: 3,994
