Zum Hauptinhalt wechseln
2012-2018 Nissan Versa Note Headlight Bulb Replacement
Was du brauchst
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: Schritt 1, Bild 1 von 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: Schritt 1, Bild 2 von 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 2, Bild 1 von 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 3, Bild 1 von 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 4, Bild 1 von 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 5, Bild 1 von 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 5, Bild 2 von 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 6, Bild 1 von 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 7, Bild 1 von 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 7, Bild 2 von 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 8, Bild 1 von 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 8, Bild 2 von 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 9, Bild 1 von 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 10, Bild 1 von 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: Schritt 10, Bild 2 von 2
    • Insert the connector into the bulb.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 63
Letzte 30 Tage: 272
Insgesamt: 12,441
