Einleitung
This guide will teach you how to replace the cabin air filter on a Fourth Generation (2012-2016) Honda CRV car.
The cabin air filter is a key part in your vehicle's ventilation system. Your cabin air filter should be replaced with a new one every 50K kilometers or 31K miles to ensure clean and safe air is being circulated throughout the cabin.
The correct filter to use in Fourth Generation (2012-2016) Honda CRV's is the CF10134 cabin air filter. The CF10134 filter is linked in the parts section of this guide.
Before you begin, make sure your car is off and in park.
Was du brauchst
Push the latch at the bottom right of the glove box towards the front of the vehicle until the latch becomes unhinged.
Push both sides of the glove box towards each other and pull down to release glove box.
Push the tabs on the left and right side of the air filter compartment inward, to remove the cover.
