Zum Hauptinhalt wechseln
2012-2016 Honda CR-V Oil and Oil Filter Replacement
Was du brauchst
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: Schritt 1, Bild 1 von 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: Schritt 1, Bild 2 von 2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 2, Bild 1 von 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 2, Bild 2 von 2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 3, Bild 1 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 3, Bild 2 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 3, Bild 3 von 3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 4, Bild 1 von 1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 5, Bild 1 von 1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 6, Bild 1 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 6, Bild 2 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 6, Bild 3 von 3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 7, Bild 1 von 1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 8, Bild 1 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 8, Bild 2 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 8, Bild 3 von 3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 9, Bild 1 von 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 9, Bild 2 von 2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 10, Bild 1 von 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 10, Bild 2 von 2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 11, Bild 1 von 1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 12, Bild 1 von 1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 13, Bild 1 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 13, Bild 2 von 3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: Schritt 13, Bild 3 von 3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Clay Casey
325 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 19
Letzte 7 Tage: 137
Letzte 30 Tage: 721
Insgesamt: 20,661
