Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace a 2012-2016 Honda Civic key remote battery.
  1. Lay the key down so that the Honda symbol is facing upward. Use a Phillips #0 screwdriver to remove one screw.
    • Lay the key down so that the Honda symbol is facing upward.
    • Use a Phillips #0 screwdriver to remove one screw.
  2. Insert the flat end of your spudger into the notch in the side of the key/remote. Pry the key remote apart to remove the cover.
    • Insert the flat end of your spudger into the notch in the side of the key/remote.
    • Pry the key remote apart to remove the cover.
  3. Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
    • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
    • Remove the battery.
    • Your key may contain either a CR1616 or CR1620 battery. In some cases either type will work, but for best results, replace it with the same kind of battery that originally came with your key.
    • Install your matching new battery in the same orientation as the original.
  4. Place the two halves of the remote cover back together.
    • Place the two halves of the remote cover back together.
    • Press the unlock or lock buttons to make sure the remote is working.
    • Place the screw into the hole and tighten with a Phillips #0 screwdriver.
Abschluss
15 weitere Nutzer haben diese Anleitung absolviert.
monica
376 Reputation
1 Anleitung geschrieben
Baylor, Team 5-7, Williams Spring 2015 Mitglied von Baylor, Team 5-7, Williams Spring 2015
BU-WILLIAMS-S15S5G7
4 Mitglieder
8 Anleitungen geschrieben
21 Kommentare
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Harry - Antwort
Thanks, Harry!
Michelle Henderson -
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert - Antwort
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Arlen Kerbaugh - Antwort
Thank you very helpful!!!
inakwana waka -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 73
Letzten 7 Tage: 451
Letzten 30 Tage: 2,204
Insgesamt: 268,547
