Einleitung
This guide is meant to help replace the cabin air filter on a 2012 Acura TSX.
Cabin air filters are made of multi-fiber materials, including paper cotton, that help prevent dirt, pollen, dust, bacteria, insects, and even bigger things like leaves from entering your car. It is recommended that for every 15,000-30,000 miles, the air cabin filter should be replaced with a new one. Replacing an old filter with a new one will improve driving comfort and the efficiency of the HVAC system, which falls under air conditioning and defrosting. Replacing the cabin air filter requires no tools and is easy to complete in a short amount of time.
Was du brauchst
Find the two clamps on the left and right sides of the cover and with one or two hands, push the clamps inwards and pull out the cover, showing the frame that holds the cabin air filter.
Locate the clips on the left and right sides of the frame.
Push the clips inwards and pull until the frame comes out.
Discard the old cabin air filter and place the new one on the frame
To properly place the cabin air filter, we must align the gaps on the left and right sides of the cabin air filter with the sides left and right side of the plastic chassis.
Finish by placing the new cabin air filter with the frame together into the car.
