Zum Hauptinhalt wechseln
2012 BMW 3 Series Windshield Wiper Replacement
Was du brauchst
  1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: Schritt 1, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: Schritt 1, Bild 2 von 2
    • To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
    • This is done to prevent scratches from developing throughout the repair process.
  2. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 2, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to pop the cover off that holds the wiper in place.
  3. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 3, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 3, Bild 2 von 2
    • Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
  4. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 4, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 4, Bild 2 von 2
    • Install the replacement wiper so that the slightly bent angle side faces the vehicle.
  5. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 5, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 5, Bild 2 von 2
    • Check that the screw is aligned with the hole.
    • With a little pressure, slowly slide the new wiper into place.
  6. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 6, Bild 1 von 2 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 6, Bild 2 von 2
    • Once it is positioned correctly, lock the cover to keep the blade in place.
    • If you hear a click, you will know you have succeeded.
    • Lower the windshield wiper carefully onto the windshield.
  7. 2012 BMW 3 Series Windshield Wiper Replacement: Schritt 7, Bild 1 von 1
    • Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
    • You are done if they are wiping properly. If they appear to be loose, make sure they are securely attached before driving again.
Abschluss
Hafsa Yusuf
145 Reputation
1 Anleitung geschrieben
York University, Team R-30, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-30, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG30
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 1,020
